ᐅ Topdressing a Lawn – Which Type of Sand Is Best?
Created on: 31 Mar 2022 13:42
BBaumeister
Since my lawn has become very uneven and the area near the forest at the back is quite muddy, I want to topdress the lawn with sand and level it.
My plan is to spread about 10 liters of sand per square meter, smooth it with a lawn rake, overseed, roll it, cover with topsoil, rake again, and finish.
My building materials supplier offers the following types of sand (I don’t want to buy lawn sand from the hardware store because of the price and the fact that I will need about 3 tons due to the area):
- Washed silver sand (play sand)
- Rhine sand 0/2
- Concrete sand 0/2
Which one is most suitable?
tomtom791 Apr 2022 08:24
Nice-Nofret schrieb:
Normal sand, grain size 3 - 4mm (0.12 - 0.16 inches)
Sorry, but I don’t know of any sand with a grain size of 4mm (0.16 inches); that is more like fine gravel.
tomtom791 Apr 2022 08:30
I did this project 2 years ago. I mixed 70% sand from the building yard, which cost 24 per ton gross, with 30% soil.
Before applying, I mowed the lawn as short as possible.
I spread the mixture using a homemade lawn rake. It works great.
Only in spots that were deeper did the grass not manage to grow, so I had to reseed those areas.
Now, after 2 years, it would be necessary to repeat the process because holes have formed again. But I’m not motivated to do it right now.
WilderSueden
1 Apr 2022 08:32
BBaumeister schrieb:
Thanks also for the tip about the drainage. We actually installed drainage pipes because the ground is extremely clayey and rocky. Naturally, they shouldn’t get clogged.
I wasn’t referring to the drainage pipes. Sand simply has a water-draining effect (called drainage). This improves the more it avoids clumping and the more space there is between the grains.
tomtom79 schrieb:
Sorry, but I don’t know any sand with a grain size of 4mm (0.16 inches); that would be more like fine gravel.
My local gravel plant still classifies that as sand.
Table showing types of washed sand and gravel sand for construction projects with grain sizes
Pamiko
1 Apr 2022 12:43
Ideally, washed quartz sand with a grain size of 0-2mm (0-0.08 inches)
