ᐅ Looking for possible sofa and TV arrangements in the living room.
Created on: 2 May 2020 21:25
DjMannarino
DjMannarino
2 May 2020 21:25
My wife and I are looking for a suitable arrangement for the sofa and TV in our future living room (the house is currently under construction). We have two ideas but are not entirely convinced by either. If you have any other good suggestions or could share your opinions on our ideas, it would be very helpful for us.
I have attached two photos showing the floor plan and a diagram of the sofa and TV positions as we imagined them. The two floor-to-ceiling windows face west, and the other floor-to-ceiling window faces south.
We would really appreciate your feedback.
Grundriss eines Wohnhaus-Erdgeschosses mit Küche, Wohnen, Diele und Bad
Grundriss eines Apartments: Küche, Wohnen, Diele, Bad, HWR; blaue Markierungen.
Xingwei4212 May 2020 21:44
Two ideas:
1. Move the patio door to the right, toward the TV area
2. Swap the kitchen and living area
(Rough sketch of the positions without regard to proportional scale)
Floor plan of an apartment: kitchen, living room, hallway, bathroom, utility room, and stairs.
Floor plan of a house with kitchen, living area, hallway, and bathroom.
DjMannarino
2 May 2020 21:55
Xingwei421 schrieb:
Two ideas: 1. Move the patio door to the right, towards the TV 2. Swap the kitchen and living area (Roughly sketched positions only, without regard to proportional scale)
DjMannarino
2 May 2020 21:58
Thank you,
Changes to the floor plan are no longer possible, as the shell construction is already complete.
kbt09
2 May 2020 23:00
Well, first you should properly furnish the room according to the current kitchen layout and also include the dimensions of the dining table. Additionally, mention the size of the sofa.
I find both options in post 1 to be rather unfortunate, considering the room is only 838cm (331 inches) long, so it’s not very spacious.
Could one of the patio doors be replaced with a window with a sill?
And honestly, these are the kinds of considerations you should be making before construction starts.
chrisw81
4 May 2020 10:01
I find the whole room a bit small in general to fit the kitchen, dining table, and sofa comfortably.
For comparison, our length is 10.8m (35 ft 5 in) instead of your 8.40m (27 ft 7 in), and even then, I don’t think it’s too much.
But if the furniture isn’t too large, it should work.
And I also have to agree with @kbt09, this is something you should at least have a rough idea of during the planning stage, not just starting now.
Plan 1: This is probably the most sensible option, although you’re blocking the floor-to-ceiling window, which you wouldn’t have had to do otherwise.
Unfortunately, the distance between the sofa and table is still quite tight here.
Plan 2: There’s not enough space between the sofa and TV, and you won’t be able to pass between the sofa and the table anymore.
