ᐅ Is a wood-burning stove room air-independent?
Created on: 19 Mar 2020 15:22
Reini1234
Reini1234
19 Mar 2020 15:22
we are planning to have our wood stove inspected soon. We have installed a chimney with a fresh air supply, and the stove is already at home and can operate independently of the room air. The connection for the flue pipe was prepared at the factory.
The chimney sweep, however, has definitely required a pressure monitor due to the existing controlled ventilation system, which has also been installed.
For independent room air operation, I would now need to create an additional fresh air connection to the chimney, which of course involves costs. Now I am wondering if this effort is even worth it since the pressure monitor is already installed and the controlled ventilation system constantly provides fresh air.
Does anyone have experience with creating the fresh air connection? Is it just a matter of drilling a hole up to just before the clay liner?
19 Mar 2020 23:11
Reini1234 schrieb:
The connection for the flue pipe was factory-prepared.
Reini1234 schrieb:
For the room air-independent operation, I would now need to create an additional connection on the chimney for fresh air,
What does that mean? Either the chimney supports room air-independent operation and is connected accordingly, or it does not. The room air-independent system works within the chimney itself, meaning it draws air from above. So, either your chimney supports this or it doesn’t, based on my understanding.
If your chimney technician is demanding something, then something may be missing.
The pressure monitor is designed to switch off the mechanical ventilation system if there are pressure differences—you would suffocate following your logic.
Who is installing your fireplace?
We had no additional costs beyond the air-independent chimney, the fireplace installation, and the chimney inspection.
wrobel19 Mar 2020 23:39
Hello
A look at the chimney installation manual will definitely help when connecting the fresh air intake.
The connection to the stove shouldn’t be a problem after that. So just do it!
The pressure switch shuts off the controlled mechanical ventilation if, for example, a clogged fresh air filter prevents the required air volume from being supplied. Otherwise, the controlled mechanical ventilation would carry away the combustion gases.
Olli
E
Egberto
20 Mar 2020 00:29
If you install a dibt-certified wood stove, a pressure monitor is not necessary,...
20 Mar 2020 01:18
That is not correct. What matters is what the local chimney inspector or official says. "His decision is final."
U
user-d29
20 Mar 2020 07:33
Egberto schrieb:
If you install a dibt-certified wood stove, you don’t need a pressure monitor,...
This is actually decided by the chimney expert. It depends on the controlled ventilation system.
