ᐅ Single-family house floor plan (approximately 1,830 sq ft) with garage – hillside location
Created on: 13 Apr 2018 18:48
Marco0581
Hello dear forum,
What do the professionals think about the following floor plan (especially regarding the questions described below)? Does anything stand out as something that shouldn’t be done?
Thank you in advance
Plot size: 800 m² (8,600 sq ft)
Slope: yes
Site coverage ratio
Floor area ratio
Edge development: see attachment
Number of parking spaces: Garage for 2
Number of floors: 2 (ground floor and upper floor without basement)
Roof type: flat roof with ventilation cavity
Architectural style
Orientation: see attachment
Maximum heights / limits
Other requirements: none
Basement, floors: No basement, 2 floors
Number and age of occupants: 2 (36 + 34)
Space requirements ground floor, upper floor: GF 90 m² (970 sq ft); UF 80 m² (860 sq ft)
Office: family use (office + guest room)
Guests per year: 10
Open kitchen, kitchen island: open
Number of dining seats: 6–8
Fireplace: yes
Music/stereo wall: no
Balcony, roof terrace: balcony
Garage, carport: garage
Other: sauna
Designed by: DIY + architect
What do you particularly like? Why?: Open living area with fireplace/sauna integration
What don’t you like? Why?: Ground floor too conventional; rooms arranged in a row
Cost estimate according to planner: 300,000
Personal budget limit for the house, including equipment: 360,000
Preferred heating technology: gas condensing boiler with solar thermal
If you have to give up, which details/extensions
- Can give up: fireplace
- Cannot give up:
Due to the sloped plot, it is not really possible to build a terrace with a view. Therefore, the living area moved to the upper floor, and for summer, we thought sitting on the balcony would work. However, the balcony as drawn seems too small. Would it make sense to use the garage roof for the balcony? (a rough 3D draft is attached)
The original design planned the heating/utility room in the garage. Because of the edge development regulations and additional insulation needed for this room, it was moved to the ground floor. As a result, a bathroom had to shift upstairs to the upper floor, where a storage room had to be removed. We fear there will be too little storage space overall. Do you see it the same way?
Note: Since we are still in the planning stage, not all views are up to date. At the very beginning, the upper floor was shifted in relation to the ground floor. Also, the garage wasn’t directly placed on the plot. I have attached the views anyway to show the orientation. The satellite photo also shows the earlier status.
Slope: yes
Site coverage ratio
Floor area ratio
Architectural style
Guests per year: 10
Fireplace: yes
Other: sauna
- Cannot give up:
Marco0581 schrieb:
Hopefully, the slope of the site can be seen reasonably well in the photos... Emphasis on "reasonably" – a site plan with contour lines or elevation points would be helpful. Also, information on the direction each photo is facing.
haydee schrieb:
Try googling the energy-saving house on a slope. I only found one by architect Häublein with a transverse beam floor plan in roughly a 3:1 ratio, which doesn’t seem applicable here (?)
haydee schrieb:
No, it’s not directly transferable. It’s also too large. Just as a suggestion, I don’t quite see where you find any resemblance, or why this particular example comes to your mind (?)]
