ᐅ Mechanical ventilation with heat recovery: no – explanation provided in the text.
Created on: 15 Jul 2015 00:00
Grym
For a long time, I was very much in favor of controlled residential ventilation, but I have now revised my opinion. First, some basic considerations:
- Modern houses are built so tightly that additional mechanical ventilation is necessary; otherwise, windows must be opened several times a day, summer and winter, for airing out
- Whether this ventilation is manual or automatic is a matter of comfort
- Whether this ventilation includes heat recovery or not is a question of economic efficiency
When considering economic efficiency, cleaning costs must be included. A reputable provider who only sells controlled residential ventilation estimated these costs at 700 EUR, with a recommended cleaning interval of at least every 5 years. However, in the demonstration house, the first cleaning was done after only 2 years because a microbial test detected contamination in the supply air exceeding the limit values (I don’t know the exact limits, but if the seller says cleaning after 2 years was necessary, I take their word for it—the company does not sell a house without controlled residential ventilation).
Depending on whether you divide the 700 EUR over 5 years or 2 years, the annual maintenance costs come to between 140 and 350 EUR.
The unit itself consumes electrical energy, approximately 250–400 kWh_el per year, which costs between 63 and 100 EUR annually.
The controlled residential ventilation system is a technical device; assuming a service life of 15 years, removal and disposal of the old unit, a new unit, and commissioning are estimated at around 5,000 EUR. This results in an annual depreciation of 333 EUR. If the ventilation system is expected to last 20 years, with disposal, new unit, and commissioning costs totaling 4,000 EUR, then depreciation is 200 EUR per year.
For new filters, maintenance, and minor repairs, I estimate a flat rate of 100 EUR.
Total annual costs in the best case scenario: 140 + 63 + 200 + 100 = 503 EUR
Total annual costs in the worst case scenario: 350 + 100 + 333 + 100 = 883 EUR
The savings effect is roughly estimated at about 2,000 kWh_thermal up to over 3,000 kWh_thermal. 2,000 kWh_thermal equate to 2,000 kWh of gas at 5.5 cents or 400–500 kWh_el at 20 cents (heat pump tariff) or 25 cents (household electricity). This results in savings of about 110 EUR (gas), 125 EUR (air-source heat pump with household electricity), or 80 EUR (ground-source heat pump with heat pump electricity).
At 3,500 EUR savings, this corresponds to 193 EUR (gas), 219 EUR (worst-case heat pump), or 140 EUR (best-case heat pump).
If you compare the best-case controlled ventilation with the worst-case heat pump, you get 503 EUR - 219 EUR = 284 EUR. The other way around is 883 EUR - 140 EUR = 743 EUR.
No matter how you look at it, controlled ventilation with heat recovery cannot even save the running costs. Therefore, in my opinion, the best system—especially to avoid hygienic problems in the house—is exhaust air modules in wet rooms combined with window rebate ventilation or an external wall air inlet. Decentralized controlled ventilation systems with heat recovery do not have such high cleaning costs, but even they would never recoup the additional cost of heat recovery. Additionally, these devices must be placed in bedrooms and living areas, which creates noise. Pure exhaust air systems without heat recovery are suitable in rooms where quiet noises are less disturbing (kitchens, toilets, utility rooms, bathrooms) and can even be switched off for hours (bathroom). Modern window rebates work without drafts and reduce sound insulation by only 1 to 2 dB. Anyone living in a quiet residential area probably doesn’t mind.
I look forward to the discussion, but please keep it relevant to the topic. I am not questioning the necessity of non-user-dependent mechanical ventilation; my focus is only on central heat recovery. Central heat recovery requires the duct system, which incurs high cleaning costs, as well as a complex technical device with limited service life and high costs (unlike a standard exhaust air module without heat recovery). Controlled ventilation without heat recovery operates without the duct system.
Saruss
15 Jul 2015 16:59
My mechanical ventilation system ducts were also dry this summer, as was the heat exchanger. Can you explain that to me, Grym? The moisture recovery system does not allow germs or similar to pass through. The size difference between water molecules and bacteria/fungi is many orders of magnitude too large. Besides that, during the warm days with temperatures over 30°C (86°F) outside, the humidity was below 50%, often under 40%.
jaeger4 Jan 2016 11:00
Grym schrieb:
For a long time, I was very much in favor of mechanical ventilation with heat recovery, but I have now changed my mind.
Hello Grym, I’m in a similar situation and came across your thread during my research. Without wanting to reopen the previous discussion, I wanted to ask if you have made a decision by now? If so, how did you decide? I would appreciate a response.
Grym
4 Jan 2016 19:26
We will probably include the mechanical ventilation system with heat recovery during construction.
Retrofitting is not really an option, and having controlled ventilation is important. In the worst case, the mechanical ventilation system can be converted into an exhaust-only system, but I am hopeful that everything will work as promised. I would never choose purely manual ventilation for a new house. For me, the question was more about whether to have a central exhaust system with decentralized fresh air supply, or a central supply and exhaust system with heat recovery.
Legurit
4 Jan 2016 19:49
We currently have a mechanical ventilation system without heat recovery (the components are still missing in the openings – so these are simply wind-protected holes in the wall). In the rooms exposed to the icy east wind, you can feel some drafts and, above all, a colder indoor temperature. Therefore, I would recommend heat recovery.
Bieber0815
4 Jan 2016 20:08
Grym schrieb:
The hygiene issues of ventilation systems are well known.
Do you own a car? Or do you occasionally spend time on trains or airplanes, in office buildings or shopping centers? Or hospitals?
In the single-family home sector, I believe hygiene problems related to mechanical ventilation with heat recovery are more of an urban legend (or in isolated cases due to serious design errors).
Sebastian79
4 Jan 2016 20:11
Look at the date – the flag has already turned back a long time ago
