ᐅ What tools do I need to modify Ikea BRIMNES furniture?
Created on: 21 Mar 2020 08:37
turalsin
Hello everyone, I want to modify and adjust my Ikea Brimnes furniture a bit, but I’m not sure which tools are best for the job. Specifically, I need to loosen screws, possibly drill new holes, lightly work on surfaces, and if necessary, shorten or file some parts. I already have basic tools like screwdrivers and a hammer, but I’m missing more specialized tools and advice, especially since MDF material can be quite delicate. Does anyone have experience with Brimnes and can provide a clear list of the essential tools, including tips on how to handle them correctly? Any advice on what to definitely avoid would also be very helpful. Thanks in advance!
BARSAN
21 Mar 2020 17:54
You will need a Phillips screwdriver bit, a cordless drill, a wood drill bit, sandpaper, and a file. Be careful when drilling – work slowly. For cutting, use a handsaw or a jigsaw.
refinar
22 Mar 2020 08:43
I would like to provide a brief overview of the tools and their applications for modifying Brimnes furniture:
1. Cordless screwdriver with Phillips bits: For loosening and fastening the original furniture connectors. Important: set the torque to low to avoid damaging the material.
2. Wood drill bits (5–8 mm, 0.2–0.3 inches): Used as pilot drill bits; operate slowly to prevent splintering.
3. Jigsaw with a fine-toothed blade: For cutting, especially on edges with laminate or coating. Protect the edge beforehand with painter’s tape to avoid fraying.
4. Sandpaper grits 120 and 220: For smoothing surfaces and edges after cutting or filing.
5. File and sanding block: For precise contour shaping and rounding edges.
6. Clamps: To hold pieces securely during work steps.
Common mistakes: drilling too quickly, torque set too high, no protection of cut edges against splintering. Tip: remove loose chips after drilling and always start the screwdriver slowly.
Good luck with your modification!
RAGUGI
22 Mar 2020 09:35
In short: cordless drill, Phillips screwdriver bit, wood drill bit, fine sandpaper (grit 180+), jigsaw, and file. Be careful when drilling—go slowly and gently. Nothing else is necessary.
