ᐅ Which screws are the most important for assembling Ikea Metod kitchen cabinets?
Created on: 26 May 2021 08:17
Busin69
Hello everyone, I have a question regarding the assembly of the Ikea Metod furniture series: Which screws are truly the most important to ensure a stable and durable structure?
I mean, there are different types of screws included in the set (e.g., particleboard screws, dowels, cam connectors, etc.), but which ones should definitely not be overlooked or possibly even replaced with higher-quality alternatives? I am especially interested in the screws that have the greatest impact on the load-bearing capacity or stability of the furniture, particularly for base kitchen cabinets.
Thanks in advance for your insights!
roryvin
27 May 2021 08:29
Busin69 schrieb:
Are there any special tips to prevent chipping around the screw?
Preventing chipping in particle board is often a matter of technique:
- Pre-drilling creates space for the screw material and reduces stress.
- Using screws with a suitable thread profile distributes the force more evenly.
- Driving screws slowly and with controlled torque helps avoid overloading the material.
In general, the Ikea screws are designed for this type of material, so if used correctly, chipping is usually not a concern.
lubla
27 May 2021 09:14
In short: correctly insert chipboard screws without over-tightening and tighten the cam connectors. Done.
Friedrich
27 May 2021 10:55
Takutau schrieb:
To protect the chipboard, it can help to pre-drill before screwing
Thank you, I wasn't exactly sure about that. Until now, I feared that pre-drilling would reduce stability, but if done correctly, it seems to have the opposite effect.
Do you have recommendations for drill bit diameters to use? Should I do this for every screw or only in areas with higher load?
hauklo
27 May 2021 12:42
Friedrich schrieb:
Do you have recommendations for drill bit diameters that should be used?
From a technical perspective, the pilot hole diameter should match the core diameter of the screw shaft, meaning without the threads. This ensures the threads have enough grip without putting excessive stress on the wood.
For common metal wood screws, this usually means a drill bit around 3–4 mm (0.12–0.16 inches), depending on the screw size.
Pilot drilling is especially advisable for thick screws or near edges, where the risk of splitting is highest.
