ᐅ What should I do if a door lock on a Billy-style cabinet is broken?
Created on: 7 Jul 2024 08:37
samson4
Hello everyone, I currently have a somewhat technical issue with an IKEA Billy bookshelf: the door latch on one of the doors is broken, meaning it no longer holds properly, the door doesn’t close cleanly or lock correctly. My question is: what practical and effective steps or solutions can I take if the door latch on a Billy bookshelf breaks? Are there options to repair the latch myself, obtain replacement parts, or make sensible modifications? I would appreciate concrete suggestions and tips that also consider common causes of failure and material aspects.
lyndon schrieb:
If the plastic is cracked, IKEA offers standardized replacement parts\ Thanks, that sounds very helpful. I noticed that the small plastic latch on mine has a crack, so I suspect a full replacement will be necessary.Fitigu schrieb:
Magnetic catches are a proven alternative\ Could you briefly estimate how easy it is to install magnetic catches compared to the original catch? I ask because I’m not really experienced with repairs or routing, and I’m not sure if I can manage it well.samson4 schrieb:
Can you briefly assess how easy the installation of magnetic catches is compared to the original latch? Installing magnetic catches is usually very simple and generally only requires attaching the small plates with screws or adhesive tape. Compared to the original latch, less mechanical knowledge is needed, but you should ensure precise alignment so that the door closes properly.
