ᐅ What is the approximate additional cost for a lower roof pitch?
Created on: 24 Dec 2013 00:22
hg6806
According to the zoning plan, our roof (shed roof) must have a minimum slope of 15°.
We didn’t want more than that either, but the architect said 18° is actually the minimum that works.
Now, during the material selection phase, they suddenly talk about 22°. That is quite a lot.
We were told that with a special type of clay tile, we could manage 18°.
I did some research myself. Our standard roof tiles would be the Braas "Harzer Pfanne".
They are designed for a standard roof slope of 22°. Below that, the underlayment would probably need to be more waterproof.
Can someone give me an approximate idea of how much something like this would cost for a base area of 9m x 10m (30ft x 33ft)? When I ask the developer, I always wait many days or weeks for such information.
The developer would save money as well, since with a flatter roof there is less roof area and also fewer aerated concrete blocks and plaster are needed. I wanted to use this as an additional argument.
Even for increasing the roof overhang from 30cm to 50cm (12 inches to 20 inches), they charge 2,250, which I also find quite expensive for just a few centimeters.
Best regards and Merry Christmas
hg6806
25 Dec 2013 16:38
So maybe I wasn’t clear enough. The development plan requires a minimum roof pitch of 15 degrees. We want to have the roof as flat as possible. The architect said at least 18 degrees; otherwise, it would get too expensive, but the builder suddenly wants 22 degrees. However, the offer and the already approved building permit / planning permission state 18 degrees. So I don’t see why I should pay more for that. An offer is an offer. They should actually be familiar enough with their roof tiles. It’s just the standard tile we are using.
nordanney
26 Dec 2013 18:51
I don’t understand the problem. If you have a written offer specifying an 18-degree roof pitch, then just accept it. If you have already accepted it, it is not your problem.
Bauexperte
27 Dec 2013 10:46
hg6806 schrieb:
The development plan states a minimum of 15 degrees. We want the roof to be as flat as possible. The architect said at least 18 degrees, otherwise it will be too expensive,
I don’t have to understand your architect – why would a roof pitch of 18° be cheaper than one with 15°? Especially since in the range of pitch 12–22° the same flat clay tiles can be used. I also don’t see higher costs for the masonry; you have to comply with the development plan anyway and you can adjust the knee wall so that it matches exactly.
hg6806 schrieb:
But the builder suddenly wants 22 degrees.
The offer and the already approved building permit / planning permission always specify 18 degrees. So I don’t see why I should pay more for that. An offer is an offer. They should know their roof tiles well enough. It’s just the standard tile we are using.
You have a valid contract and an approved building permit / planning permission – I would say it is your provider’s problem if they don’t know their construction documents / contracts ... and changing from 18° to 22° is not possible without an amendment to the building permit / planning permission.
Best regards, Bauexperte
tarmo
15 May 2017 14:20
Good information, I had a similar question!
Nordlys
15 May 2017 17:36
HARZER PFANNE F+ (BRAAS 7GRAD ROOF)
However, that would work. Karsten
