ᐅ Transition from Basement Wall to Ground Floor
Created on: 9 Jun 2017 08:17
Jochen2014
There is a step of about 2.5 to 3.5cm (1 to 1.4 inches) between the basement wall and the ground floor wall. The basement wall is recessed.
I would like to improve this area and would appreciate any suggestions.
I’m not sure if I can simply level it with filler because I’m concerned that the existing wood might swell. I also considered using some kind of trim (L-profile), but haven’t found a suitable option yet.
Maybe someone here has a brilliant idea?
Thanks in advance.
Jochen
Wall with moisture damage: peeling plaster, cracks, and dark spots.
Basement corner with damaged wall, flaking plaster and moisture on the concrete floor.
11ant12 Jun 2017 14:24
Jochen2014 schrieb:
I will make more effort in the future to post clearer images here. I don’t want to hide anything; I chose the pictures where I thought the problem would be most visible.
What is hard to see is the context that helps to interpret the image. Larger sections, where you then have to search for the affected area, don’t help much either. In my opinion, the most practical approach is a combination: knowing the house as a whole and then being able to place the problem area spatially (here in floor plans or cross sections; for the terrace edge question, a site plan would be appropriate at this point).
There are people here who don’t share any information about their house and expect advice on how to best position their kitchen door. Others have shared their entire construction history before asking a detailed question, so regular readers almost feel at home. Regarding the usefulness of the advice that can be given, I believe there is a causal connection.
