Theneeg-17 Sep 2012 02:58My toilet cistern is continuously leaking water. Although it’s only a small amount, it drips constantly around the clock. I have now removed the cover plate from the cistern (brand: Geberit), but honestly, I’m not sure what to do next. What steps do I need to take to reseal the system? Do I need to call a professional plumber for something like this?
MODERATOR10 Sep 2012 22:15If water is constantly running, a seal inside the cistern is leaking or the float is no longer functioning properly. The float is a component inside the toilet cistern (you should be able to see it by removing the lid) that is connected to the valve via a lever mechanism; as the water level in the cistern rises, the float also rises and the valve is closed through the lever system. It is possible that something is scaled or stuck.
Kajaxik-113 Aug 2013 16:58I had exactly the same problem, and in my case, it was also the float. Thanks for the help 🙂
Kurt1985-113 Jun 2014 07:25Fortunately, this happens only rarely, but it was also the float. It had become stuck, and I was able to free it without any trouble.
