ᐅ System diagram including buffer tank and solar thermal system
Created on: 11 Oct 2023 22:16
Losgehtss
Losgehtss
11 Oct 2023 22:16
Hello
I am modifying my heating system. A 1000L (264 gallon) hygienic buffer tank with 6 solar thermal collectors will be added to an existing gas condensing boiler. I have drawn a system diagram and would like to know if you would set it up the same way.
There is an underfloor heating system installed.
Regarding the diagram, I need to explain what I have in mind:
The controller is supposed to measure return flow sensor 1 and buffer sensor 2 and control a 3-way valve. If sensor 1 is colder than sensor 2, the buffer heat is fed into the gas unit. If it is warmer, the buffer is bypassed.
Schematische Heizungsanlage mit Pufferspeicher, Fußbodenheizung, Trinkwasser und Solarunterstützung.
RotorMotor
12 Oct 2023 09:11
Better to use photovoltaics with an electric heating element than solar thermal systems. ;-)
