ᐅ Manufacturers / Brands for Central Ventilation Systems? Selection Criteria?
Created on: 18 Oct 2021 18:16
HoisleBauer22
I am currently planning my detached single-family house with a manufacturer of solid prefabricated houses.
Which suppliers/brands are available for central ventilation systems? What criteria should I use to choose one?
19 Oct 2021 21:17
HoisleBauer22 schrieb:
Maybe it’s because we are relatively new to the forum and haven’t yet made four-digit numbers of posts?
Those who don’t write much can read a lot 😉
11ant20 Oct 2021 13:43
Maybe it’s because we’re relatively new to the forum and haven’t posted in the four-digit range yet?
It probably has more to do with manners—whether you jump straight in with “your” question or first take a look to see if it has already been asked.
Those who don’t write can read a lot
The post counter only records the posts you write; I’ve probably read about five times as many.
Grobmutant
20 Oct 2021 17:45
As a manufacturer, I have read a lot of good things about Zehnder and Helios, but even the best technology does not matter if it is not well planned and installed. This means that the craftsman and the planning are also crucial.
Mycraft20 Oct 2021 21:10
@HoisleBauer22
In terms of quality, they are all quite similar. The main differences are basically the additional features and the software. The fans are often from Helios or Papst, regardless of which brand label is on the unit. Otherwise, it's mostly just metal, polystyrene, and a control system.
Based on the size/type/dimensions of the heat exchangers and the system configuration, you can usually identify the original manufacturer.
HoisleBauer22
20 Oct 2021 21:13
That is already very interesting, thank you!
HoisleBauer22
22 Oct 2021 22:09
I recently found out that you can compare various ventilation systems on the European Testing Center for Residential Ventilation Devices website. They also offer a cost calculator. I came across the link through the consumer advice center’s page "Ventilation System: What to Consider in Planning."
The testing center’s website also has a FAQ section called "10 Questions About Ventilation." The information there is probably a bit outdated. Maybe one of you experts could take a look and see if much of it is still relevant and whether it is recommended.
