ᐅ Shower drain installed too high, so it was ground down, now there is a hole.
Created on: 1 Nov 2020 08:35
Tx-25
Hello, our shower channel was installed too high. Unfortunately, we don’t have an invoice for the work. We thought it over and decided to grind down the channel. Now we have a big problem. The channel was double-walled, and we have ground it so much that there is now a gap. Of course, we didn’t know that the channel was double-walled.
Please no comments like "serves you right without an invoice," etc. We’re already kicking ourselves enough!
Of course, the worst case would be to remove all the tiles and the channel and start over.
Do you have any other ideas? Is it possible to reseal the channel? It is made of stainless steel. We were thinking about soldering?
Close-up of a flat metal container with white powder dust in the corner.
Close-up of a black surface with a grey edge and ventilation slots behind.
Nida35a1 Nov 2020 11:40
Expand the gutter,
deepen the hole,
install and seal the new gutter,
give away the angle grinder, not to a friend
Tx-25
1 Nov 2020 11:51
Even though it doesn't really matter: we modified the trim using a rotary tool. We're not troublemakers either.
hampshire
1 Nov 2020 12:57
Tx-25 schrieb:
The gutter is already ordered. That’s probably the smallest one. But redoing everything will easily cost four figures. That really hurts. Money is tight after building a house.
Just redo it and mark it as a story you can laugh about later. That’s the fastest way. Money goes away and comes back. Frustration and bad moods cost valuable time. Time doesn’t come back. That’s why I wouldn’t waste years dealing with a temporary fix.
knalltüte
1 Nov 2020 18:55
Of course, stainless steel can be soldered! Both hard and soft soldering are possible. You just need to know how to do it. However, I cannot say whether the desired result can actually be achieved this way and if it would cost significantly less than a four-figure amount.
The "proper" way is probably to remove the old part and install a new one. Any potential water damage caused by a faulty shower channel would likely be more expensive.
U
user-d29
1 Nov 2020 19:48
Consult a locksmith experienced with stainless steel and have the repairs done professionally.
