ᐅ Have your basement room partitioned professionally or do it yourself?
Created on: 28 Jun 2021 08:38
Pwnage619
Hello
We have purchased a semi-detached house with a basement from the developer.
The standard layout includes 3 rooms: a technical/storage room and an entrance hallway.
The entrance hallway is completely open when you come down the stairs. We want to separate the hallway to create a closed room and have the corridor as a separate area.
The developer can build the partition for 3500€. This includes fully built walls (calcium silicate bricks) and a door (wall about 3-4 m (10-13 feet) wide).
Or should we just install a drywall (plasterboard) partition with a door ourselves after construction?
What is better? Is the price reasonable or way too high?
The separated room will be used with shelves as a storage room. Are drywall walls strong enough for that?
11ant28 Jun 2021 19:09
Pwnage619 schrieb:
The underfloor heating is installed; if you leave it out, there will be no credit for it.
Then build your small wall or similar at least up to the top edge of the screed before the heating loops are laid. However, I would also recommend leaving out the underfloor heating in this small room. Unless, of course, you need it there for some kind of controlled climate.
