ᐅ Have your basement room partitioned professionally or do it yourself?
Created on: 28 Jun 2021 08:38
Pwnage619P
Pwnage61928 Jun 2021 08:38Hello
We have purchased a semi-detached house with a basement from the developer.
The standard layout includes 3 rooms: a technical/storage room and an entrance hallway.
The entrance hallway is completely open when you come down the stairs. We want to separate the hallway to create a closed room and have the corridor as a separate area.
The developer can build the partition for 3500€. This includes fully built walls (calcium silicate bricks) and a door (wall about 3-4 m (10-13 feet) wide).
Or should we just install a drywall (plasterboard) partition with a door ourselves after construction?
What is better? Is the price reasonable or way too high?
The separated room will be used with shelves as a storage room. Are drywall walls strong enough for that?
O
Osnabruecker28 Jun 2021 08:49€3,500 including plaster?
It can be done more cheaply on your own.
But sand-lime brick is of higher quality.
And having everything from a single source and not having one construction phase after another would be worth the (approx.) €1,000 main contractor markup to me.
Pwnage61928 Jun 2021 08:56Yes, including Q2 plaster.
So, a drywall partition and the door (I would have to check to get the same door as in all the other rooms) would cost about €2500 if you do it yourself?
nordanney28 Jun 2021 09:00Osnabruecker schrieb:
And having everything from a single source and no ongoing construction would be worth the roughly 1,000€ (about 1,000 USD) general contractor surcharge to me.I actually just wanted to give a like, but since the original poster asked more:Pwnage619 schrieb:
The separate room is supposed to be used as a storage room with shelves. Are drywall partitions very sturdy?Drywall is just a brand name. Gypsum board walls are very sturdy if you install double layers. Alternatively, you can fix OSB first, then gypsum board. People even hang entire kitchens on these walls.For the door, budget about 400€. For the gypsum board wall materials including plastering, I’d estimate around 500€ (personal experience).
Pwnage61928 Jun 2021 09:11ok thanks
so can we say a maximum of 1000 - 1500€?
So you would recommend having the wall made directly from calcium silicate blocks? Because it is higher quality?
Or should I rather do it myself for about one-third of the price? The room will be used as a storage room and we would screw in heavy-duty shelves (but not place extremely heavy loads on them)
hanghaus200028 Jun 2021 12:36According to @nordanney, the costs are generous. In the basement, any door from a hardware store will do. With good planning, the DIY approach should be feasible.
You can’t really see the difference. Who’s going to judge that? I would prefer a DIY timber or metal stud wall. For the interior and exterior cladding, just install drywall. Double layers are not necessary.
Pwnage619 schrieb:
So you would recommend having the wall made directly from calcium silicate bricks? Because it’s higher quality?
