ᐅ Rimless Toilet: Yes or No?
Created on: 30 May 2018 10:18
Wickie
Hello everyone!
We need to order our sanitary fixtures and have just heard from acquaintances that they are not satisfied at all with their rimless toilet.
What kind of toilets have you installed – with or without a rim – and are you happy with them?
Wickie
30 May 2018 12:24
I would double-check the toilet tank with the plumber...
@ypg: it always seems to "spray under the lid," so the issue is probably really related to the flush pressure.
Thanks for your input – I think we’ll stick with the icon.
Kekse
30 May 2018 12:30
Maria16 schrieb:
At least my partner recently complained quite a bit about the yellowish discoloration on the underside of the toilet seat. I assume that nothing was splashed up from the porcelain during use, but that it’s caused by the “spitting” of the bowl – which would also mean there are (albeit minimal) urine residues on the floor.
We have the same issue with our current toilet, which has a rim flush design, so I suspect it does splash during use in our case at least.
Of course, this could be easily tested if there’s enough interest: urinate, check if splashed (wet), flush, then check again.
Maria16
30 May 2018 12:35
Maybe I should do that sometime when I’m really bored.
Musketier30 May 2018 12:36
Maria16 schrieb:
At least my boyfriend recently complained a lot about the yellowish discoloration on the underside of the toilet seat. I assume it’s not due to splashes from the porcelain during use, but rather because of the toilet bowl "spitting"-
We have that too.
There was also a thread about this here before.
30 May 2018 13:01
Wickie schrieb:
I would check again with the plumber about the flush tank...
@ypg: it always seems to spray "under the lid," so the issue is probably related to the flush pressure.
Thanks for your input – I think we’ll stick with the Icon
Oh, I see. So it’s not the flush itself, but when "urinating." We experience the same here.
The white cleaning cream makes everything white again.
Wickie
30 May 2018 13:31
Hmmmh... and I thought it was the flush pressure and not when "urinating" :P
However, this issue does actually occur with "regular" toilets as well, so I think we will indeed keep our choice. Plus the use of the cleaning cream.
Kind of a strange topic somehow.
