ᐅ Moving a Non-Load-Bearing Wall – What Should Be Considered?
Created on: 1 Oct 2017 12:39
michael.wM
michael.w1 Oct 2017 12:39Hello dear forum members, we have purchased a condominium that is not yet finished and would like to have a non-load-bearing wall modified. Are there any important factors to consider, such as underfloor heating, ventilation systems, flooring, distance to the entrance door (since it leads to an exterior wall), electrical or plumbing lines, etc.? Unfortunately, I am not an expert in this area. I would appreciate any tips on what to watch out for. The actual masonry work will be done by professionals, but I want to think through everything in advance.
Thank you very much.
michael.w1 Oct 2017 13:00Thank you very much for your reply, kbt09. That is what I want to do, but I would like to know what needs to be considered so that I don't ask very obvious questions or can ask more specific questions. The change involves a maximum of 2 m² (21.5 sq ft).
Bau-Schmidt1 Oct 2017 13:07You need to pay attention to the underfloor heating, ventilation system, electrical installations, windows, and doors.
michael.w schrieb:
distance to the front door (since it’s adjacent to the exterior wall) ... I don’t understand
michael.w schrieb:
it’s a maximum change of 2sqm (about 22 sq ft). so the storage room is supposed to be removed (?)
If a non-load-bearing interior wall is removed, nothing happens structurally. For a underfloor heating system, it would be more critical to try to anchor an additional interior wall exactly where the heating pipes run under the floor. Removing a wall in this respect would “at worst” create two sub-areas of an otherwise single room, each assigned to a separate heating circuit, with no pipes running under the removed dividing wall.
But since the heating installer comes after the masons, they will see that the wall is not there. However, if
michael.w schrieb:
you would like to have a non-load-bearing wall modified meaning its position should be changed, the situation is a bit different—especially if the wall already exists and the floor is already finished.
Still, the advice to discuss this with the property provider is definitely very important. This question is always safe to ask, no matter the level of knowledge.
