ᐅ Recommendation for Lime Plaster and Lime Paint
Created on: 8 Jun 2020 14:13
O
Olli_35
We have mold problems in the corners of our bedroom during winter. The base is gypsum plaster with non-woven wallpaper.
Now I plan to renovate the room a bit and want to remove the plaster from the exterior walls and then plaster them with lime plaster. After that, a complete lime finishing coat is to be applied. Finally, the walls should be painted with a lime-based paint.
I hope that the lime plaster will help regulate the humidity to some extent and prevent further mold growth.
I was recommended the following plasters:
Otterbein Clacea Base Plaster
Otterbein Clacea Fine Plaster
Does anyone have experience with these products, and do I need any primer between the plaster layers or between the finishing coat and lime paint?
Or can anyone recommend another plaster or paint?
Thanks in advance for the help.
Olli_35
Tolentino9 Jun 2020 09:40
No, recently it seems that both the sender and the recipient must have enough (200?) posts to be able to use private messages. The reason for this measure remains unclear as usual. Just post here instead.
Andre77
9 Jun 2020 09:52
are the return lines 50RAS
nordanney
9 Jun 2020 10:36
Thanks also from me for the tip. I am also looking for an alternative for a decentralized ventilation system.
O
Olli_35
9 Jun 2020 10:44
Thanks for the recommendation, they look quite solid. The price is also reasonable.
fach1werk
12 Jun 2020 07:16
We have the Vento Ergo A50-1 Pro installed. It does not have a timer function. We switch it on and off manually using a battery-powered remote control. It has been running well for 3.5 years, and we are very satisfied. Initially, it disturbed Mr. Fachwerk's sleep slightly for about two weeks, but after that it was fine.
Gabriele
