ᐅ Driven well – which type of pump or similar equipment is recommended?
Created on: 14 Mar 2023 16:36
X
xxsonicxxWe have recently completed a driven well (8.00 m deep) and now we are wondering about the right pump to use!????
We would like to run 2-3 garden sprinklers with it. The well is located inside an infiltration shaft. Therefore, I would like to install the pump there as well. Supply lines and so on are already in place.
Does anyone have any tips or suggestions, or what should we consider when buying a pump… what features or capabilities should it have?
Allthewayup14 Mar 2023 20:18What is the diameter of the well?
What I don’t understand is how a well can be located inside a soakaway pit. A photo might clarify this.
What I don’t understand is how a well can be located inside an infiltration shaft. A photo might clarify that.Since the shaft was already there and is 4.50m (15 feet) deep, we installed the pipe there… saving the effort of drilling 4.50m (15 feet). Here’s a quick image I found online.
So basically a standard driven well with a hand pump and a branch for a submersible pump.
hanghaus202312 Apr 2023 13:07For a suction pump, this is quite deep.
Where is the water level?
For a pressure water pump, the pipe diameter is rather small. What is the internal diameter of the RDM?
hanghaus202312 Apr 2023 13:25It is also possible with a jet pump from a depth of 8 m (26 ft), if both pipes and the Venturi tube fit inside.
For example:
Water pump 750 W 230 V suction height 23 m (75 ft) 2520 L/h jet pump
For example:
