ᐅ Driven well – which type of pump or similar equipment is recommended?
Created on: 14 Mar 2023 16:36
X
xxsonicxx
We have recently completed a driven well (8.00 m deep) and now we are wondering about the right pump to use!????
We would like to run 2-3 garden sprinklers with it. The well is located inside an infiltration shaft. Therefore, I would like to install the pump there as well. Supply lines and so on are already in place.
Does anyone have any tips or suggestions, or what should we consider when buying a pump… what features or capabilities should it have?
Dogma
12 Apr 2023 14:22
I used a KSB MultiEco 35 for my approximate 8m (26 feet) deep driven well [could also be a 36, I would have to check the nameplate]. It has now been running for 7 years with extremely iron-rich water, but it works like clockwork.
xxsonicxx13 Apr 2023 08:09
Dogma schrieb:
I use a KSB MultiEco 35 for my approximately 8m (26 feet) deep driven well [it might be 36, I would have to check the nameplate]. It has now been running for 7 years with water that has very high iron content, but it runs like clockwork.
Thanks for the tip. Funny enough, I had already looked into that one yesterday.
xxsonicxx14 Apr 2023 10:26
@Dogma
Doesn't that unit have too much power for the driven well?...not that it clogs up and runs dry!?
Dogma
14 Apr 2023 13:32
@xxsonicxx
Power already has the unit; in the largest irrigation circuit, there are 4x Gardena T380 + 1x T200 connected. It should deliver about 3.5 square meters per hour at 3 bar (43.5 psi).
My well hasn’t clogged yet, but every 3-4 days I need to clean the pump pre-filter from sand.
xxsonicxx14 Apr 2023 14:09
Dogma schrieb:
@xxsonicxx
The unit already has power; in the largest irrigation circuit, there are 4x Gardena T380 plus 1x T200 connected. It should deliver about 3.5 m²/h (37.7 sq ft/h) at 3 bar (43.5 psi).
However, my well hasn’t clogged yet, although I have to clean the pump pre-filter from sand every 3–4 days.
All right, thanks very much. Have a great weekend ☀️
