ᐅ Rain shower drips intermittently
Created on: 9 Feb 2015 23:31
martinschm79
Hi,
we installed a square rain shower from IdealStandard. Lately, it has started dripping on its own more often. The last use was easily 12 hours ago. Sometimes only one of the outlets drips, sometimes several.
Do you have any idea what might be causing this?
Cheers
Martin
FrankH
4 Nov 2015 17:32
wrobel schrieb:
Hello again
the solution could be to tilt the showerhead after use.
If air enters at the top edge, water can exit at the bottom.
This way, air also enters the shower arm more quickly.
Olli
My bathroom planner also recommended tilting the showerhead so that the remaining water can drain out.
wrobel4 Nov 2015 17:54
Hello again
Sorry..... it was already pointed out
That’s what happens when you jump in without reading everything.
Olli
f-pNo5 Nov 2015 11:33
wrobel schrieb:
Hello again
Sorry..... someone already pointed that out.
That’s what happens when you jump in without reading everything first.
Olli
It's nice to be confirmed by a professional.
5 Nov 2015 14:20
f-pNo schrieb:
After showering, we pull the water off the walls and floor toward the drain. Maximum duration: 2 minutes. This helps the shower area dry much faster and reduces the risk of unsightly water stains, limescale (our water is unfortunately very hard), and potential mold growth.
This has been discussed before—we also pull water off our tiles, and finally wipe the fixtures dry with a damp towel. It takes less than a minute and saves a lot of time and money on weekly cleaning and limescale removal, which then becomes unnecessary.
f-pNo6 Nov 2015 14:18
This has already been discussed once, ...
I know – one or two days in advance.
However, if someone asks me something like, "Why on earth are you going through all this effort?" I don’t want to leave them without an answer.
