ᐅ Radon Protection Measures
Created on: 21 Jul 2019 17:25
U
unser_schloss
U
unser_schloss
21 Jul 2019 17:25
I have a question about radon protection measures, as I have heard different opinions from experts.
I have read that certain protective measures are recommended in radon precaution areas. I also found a map online with values for all of Germany. However, I couldn't find any information about the threshold value that defines a radon precaution area. So, I don’t know if our area is affected at all.
I would also be interested to hear if anyone here has taken radon protection measures and, if so, which ones.
Thank you and best regards
hampshire
21 Jul 2019 18:32
Our best protection is a preference for fresh air. The windows are actually almost always open, and in winter we ventilate frequently with quick bursts of fresh air.
The amount of radon in the soil is only one factor among several. What really matters is how much radiation exposure you have inside the house. Radon is part of the decay chain of uranium and has a half-life of a few days. Its radiation is alpha radiation, which hardly penetrates the skin. It only becomes critical in higher concentrations inside the body itself (as has been known since the Polonium poisoning of Litvinenko). You can measure radon levels in your home to see where you stand.
Here are a few notes:
1. The further a room is from the earth’s surface, the lower the radiation exposure.
2. The less permeable the soil, the less radon "wants" to enter the house.
3. The higher the building's surface weight, the higher the diffusion pressure for radon. The potential exposure in the basement of a high-rise is much greater than on the ground floor of a prefab house.
4. What determines a health risk is the amount of radiation (sieverts) over time. This varies from house to house.
5. If you want to minimize radiation through construction, use less concrete – keep in mind roofing materials as well.
6. Overdoing mitigation measures can be expensive.
Regarding the "fear of radiation" topic – nowadays, the internet mainly fuels fears. Some sources claim that radon exposure is the second most common cause of lung cancer after smoking. The radon-lung cancer issue has only come up recently as people live longer and certain early causes of death have been medically reduced in significance. Keeping an eye on it is certainly sensible, but getting overly worried only makes you vulnerable to those who profit from fearmongering – that market is growing.
Niloa
21 Jul 2019 19:32
I once saw this on an episode of "Zuhause im Glück." They measured high levels inside the house because it was built into a hillside. I believe they installed some kind of ventilation system.
U
unser_schloss
21 Jul 2019 20:58
Thank you for your replies.
Since the Federal Office for Radiation Protection is also involved in this matter, I assume it is not just fearmongering by charlatans.
As mentioned, the question is certainly which areas are affected by the measures mentioned.
haydee
21 Jul 2019 21:12
Ventilation is an important measure
Sealing the foundation slab with Katja Sprint
The building entry point for utility lines must be sealed
When reading this, much seems standard, and radon is more likely to be an issue in older buildings than in modern new constructions.
