ᐅ Question about house dimensions
Created on: 21 Feb 2016 15:35
Der-w
Der-w
21 Feb 2016 15:35
Hi,
If you have a building plot with dimensions of 12m x 6m (39ft x 20ft) for a semi-detached house, which part of the house must comply with this measurement? The exterior render, the insulation, or the structural shell? With 15cm (6 inches) of insulation, this already makes a difference.
Thanks.
Regards,
Der-w
T21150
21 Feb 2016 17:12
Hi,
the exterior walls (I mean plastered).
Protrusions (e.g., front door) are probably regulated by the building code or planning permission of the respective federal state (percentage of the respective width that is not counted, for protrusions of xy m (xy feet)).
Thorsten
Der-w
21 Feb 2016 21:03
How sure are you?
21 Feb 2016 23:22
For new construction, the external dimensions apply.
For renovations, it is usually allowed to build on top.
Bauexperte
22 Feb 2016 00:04
Der-w schrieb:
If you have a building envelope of 12 m x 6 m (39 ft x 20 ft) for a semi-detached house, which part of the house must comply with this dimension? The exterior plaster, insulation, or the structural shell?
With 15 cm (6 inches) insulation, it makes quite a difference.
The exterior plaster—and yes, I’m absolutely sure about that… before you ask 😀
Regards, Bauexperte
