ᐅ Proper Ventilation Practices Without a Mechanical Ventilation System
Created on: 28 Nov 2019 18:00
seat88
You often read that proper ventilation means opening all windows at least three times a day, doing shock ventilation for ten minutes, etc., to remove moisture. However, in our house (timber frame construction, everything dry, and windows with trickle vents), we have a hygrometer in every room showing humidity levels between 40 and 50 percent.
In my opinion, this means I can skip the forced ventilation several times a day, right? It should be enough to ventilate once in the morning after sleeping and after showering, or whenever there’s a smell from cooking, correct?
Mycraft29 Nov 2019 22:39
but not as comfortable, and you still have to be able to breathe...
29 Nov 2019 23:21
Bookstar schrieb:
I agree, I have an unsettled digestion and need to pass gas frequently, so in the bedroom there's not a tiger cage in the morning but pleasantly fresh air. My wife is happy too.
Just don’t expect the same quality from both options.
Reini1234
2 Dec 2019 11:20
michert schrieb:
A proper talking-to would have been cheaper
he has probably already been getting that every morning from his wife...
Bookstar
2 Dec 2019 13:51
You guys are such jokers!
Fleckenzwerg
11 May 2020 12:12
You should regularly ventilate every room where humidity can develop or increase (primarily due to people, but also plants, aquariums, etc.). It is NOT enough to just check the hygrometer and think, "Oh, 40% relative humidity, so I don’t need to ventilate." These devices only measure humidity at a single point, specifically where they are located. However, humidity levels can vary in every corner of a room. There was a case where mold developed in a bedroom despite daily quick ventilation (windows open, door open, cross-ventilation) because the airflow only passed through a narrow part of the room, and the air in the rest of the room was not exchanged. Using a fan during ventilation solved the problem after one week.
Mycraft11 May 2020 12:18
Fleckenzwerg schrieb:
There was a case where mold developed in a bedroom despite daily intensive ventilation (windows open, door open, cross-ventilation),
A case?
I would say this is not unusual and happens more often than you might think.
