ᐅ Proper Ventilation Practices Without a Mechanical Ventilation System
Created on: 28 Nov 2019 18:00
seat88You often read that proper ventilation means opening all windows at least three times a day, doing shock ventilation for ten minutes, etc., to remove moisture. However, in our house (timber frame construction, everything dry, and windows with trickle vents), we have a hygrometer in every room showing humidity levels between 40 and 50 percent.
In my opinion, this means I can skip the forced ventilation several times a day, right? It should be enough to ventilate once in the morning after sleeping and after showering, or whenever there’s a smell from cooking, correct?
boxandroof28 Nov 2019 18:38Moisture that isn’t there doesn’t need to be removed.
readytorumble28 Nov 2019 18:53In your case, the holes in the windows (trickle vents) handle ventilation automatically.
boxandroof28 Nov 2019 21:11seat88 schrieb:
That’s why you should still ventilate sometimes.Fresh air in, stale air out.Similar topics
