ᐅ Prefabricated house, poor sound insulation / high noise transmission
Created on: 12 Nov 2019 19:05
theo1988
I live in a prefabricated single-family house built in 2017.
Unfortunately, the walls in the house are very noisy.
For example, if you put your ear against the wall, you can hear people talking on the street. Also, when cars drive by, there is a booming sound inside the house because the exterior wall is probably too light or thin.
The exterior wall consists of 80 mm (3 inches) of polystyrene insulation panels, 12 mm (0.5 inches) OSB boards, 140 mm (5.5 inches) of interior insulation, and 12 mm (0.5 inches) gypsum fiberboards.
What options are there to have the construction company make improvements?
Would it make sense to have an acoustic report conducted?
I would appreciate any help!
Regards, theo1988
Regards, theo1988
theo1988 schrieb:
Hello, would it help to install gypsum cladding on the interior walls?Probably not. theo1988 schrieb:
The exterior wall consists of 80 mm (3 inches) polystyrene insulation boards, 12 mm (0.5 inches) OSB panels, 140 mm (5.5 inches) interior insulation, and 12 mm (0.5 inches) gypsum fiberboards.What material is used for this interior insulation, and could it have settled, creating cavities that act as resonance chambers? Have you already mentioned the manufacturer here?https://www.instagram.com/11antgmxde/
guckuck2 schrieb:
Well, the weight of gypsum veneers is probably negligible.One square meter of gypsum veneer weighs about 18 kg (40 lbs).This is significantly more than a gypsum drywall panel.
