ᐅ Prefabricated house, poor sound insulation / high noise transmission
Created on: 12 Nov 2019 19:05
theo1988
I live in a prefabricated single-family house built in 2017.
Unfortunately, the walls in the house are very noisy.
For example, if you put your ear against the wall, you can hear people talking on the street. Also, when cars drive by, there is a booming sound inside the house because the exterior wall is probably too light or thin.
The exterior wall consists of 80 mm (3 inches) of polystyrene insulation panels, 12 mm (0.5 inches) OSB boards, 140 mm (5.5 inches) of interior insulation, and 12 mm (0.5 inches) gypsum fiberboards.
What options are there to have the construction company make improvements?
Would it make sense to have an acoustic report conducted?
I would appreciate any help!
Regards, theo1988
Regards, theo1988
theo1988 schrieb:
One square meter of gypsum veneer weighs about 18 kg (40 lbs).
That is significantly more than a gypsum drywall panel.18 kg (40 lbs) is still practically nothing. I wouldn’t have high hopes based on that.
Also, you have to be careful not to attach too much weight to the walls. Otherwise, it might come vi
Maybe you could try using lightweight concrete cladding. However, it might be too heavy for the gypsum fiber boards. You don’t want them to fall off again.
guckuck2 schrieb:
18kg is practically nothing, though. I wouldn’t expect much from that.
hampshire1 Nov 2020 16:07If it is really just about the mass, you can use Hawaphon.
hampshire schrieb:
If it’s really just about the mass, you can use Hawaphon.How are these used? Stuck directly to the wall? Then wallpapered over? Or how should I imagine it?H
hampshire1 Nov 2020 17:12That would look quite unusual. I would rather add an extra layer of Fermacell to one wall side and apply Hawaphon in between.
