ᐅ Plastic windows with woodgrain finish – recommendations and quality?
Created on: 23 Apr 2020 15:41
annab377
Since the additional cost for wood-effect foil coating on plastic windows is quite reasonable, we are reconsidering this option.
What experiences have you had with it? With the major window manufacturers like aluplast, Drutex, or Salamander, you generally shouldn’t go wrong. Drutex appears to be one of the more affordable options. They are from Poland, after all.
If I understand correctly, these windows are foil-coated, right? Is there any long-term experience available regarding the foil possibly peeling off at the edges after a few years? Or are the windows covered with one continuous foil rather than separate foil sections per panel, where grooves form at the edges and these ends might come loose over time?
Please share your experiences with plastic windows in wood decor.
Thank you!
PS: Is it possible to order foil samples like you can with tiles, or is it only possible to get a good impression of the texture and appearance during an in-person inspection?
Tego12
23 Apr 2020 18:11
rick2018 schrieb:
@Tego12 gray is usually powder-coated or dyed, right?
I'm no expert by any means, but as far as I know, plastic windows are usually just laminated (at least with all the homeowners I've talked to so far). To my knowledge, powder coating requires an aluminum shell, at least that's what I understand. For powder coating, you need some kind of conductive surface.
11ant23 Apr 2020 21:50
To my knowledge, the granulate used in gray or anthracite PVC windows is always white. I just checked with Gealan – a brand I usually recommend because they don’t use foil but instead “bake in” the color – and unfortunately, they do use foil for wood decor finishes. For powder coating, I can only imagine aluminum cladding shells being suitable. For wood decor, aluminum would also need to be foil-wrapped, but I don’t recall any customer requests for that, and the factory I’m familiar with operated for more than 40 years.
hanse987
24 Apr 2020 00:08
For woodgrain finishes, aluminum would also need to be foiled – but I don’t recall any customer requests for this, and “my” factory existed for more than 40 years anyway.
Aluminum can be powder-coated with a woodgrain surface using a special process. This is commonly used, for example, in aluminum facade applications.
rick201824 Apr 2020 06:18
@hanse987 I saw this when we were choosing our aluminum composite panel facade. However, I don’t think this method is used for window profiles. It is certainly feasible, though.
