Hello everyone.
Our prefabricated garage was installed on Monday. We chose a large steel prefab garage measuring 6 x 9 m (20 x 30 ft) from the company "Garagenrampe." We now want to add a partition wall inside.
I would like to build this using metal studs similar to those used in drywall construction. On these, I would first attach OSB boards, and then either gypsum board (drywall) or cement fiberboard on top.
My question is: Would this be feasible in an unheated garage where there is some moisture present? Is it possible to use OSB boards, for example? And is it really necessary to use cement fiberboard, or would impregnated gypsum boards be sufficient?
My main concern is mold growth.
Scout schrieb:
This is sheet metal. You screw on things less often here; I would prefer rivets.I would rather weld screws than rivet non-metal to metal.https://www.instagram.com/11antgmxde/
dopamine18873 Sep 2021 15:45There are L-profiles on the interior wall. According to the manufacturer, you can attach shelves, etc., there using metal screws. I will go to the hardware store in the next few days, but the option with painted OSB boards already sounds quite good.
dopamine1887 schrieb:
Hello everyone.
Our prefabricated garage was installed on Monday. We chose a large steel prefab garage measuring 6x9m (20x30 ft) from the company "Garagenrampe." We now want to add a partition wall inside.
I would like to build it using metal studs, similar to drywall construction. First, I would attach OSB panels, and then screw either drywall or cement fiber boards onto those.
Now my question: In an unheated garage, where there is some humidity, would this be feasible? For example, can OSB panels be used? And is it really necessary to use cement fiber boards, or would moisture-resistant drywall panels be sufficient?
Thanks in advance. Hello,
how is the garage and the partition wall coming along? I have the same project with 6x9m (20x30 ft) and also from Garagenrampe. Are you satisfied, and could you share some photos of the finished result?
Sven
