ᐅ Outdoor Lighting: Motion Sensors and Continuous Operation?
Created on: 9 Oct 2022 15:54
JaiBee07
I’m finding it more challenging than expected to decide on the outdoor lighting electrical setup and would appreciate your input on how you implemented yours and whether you’re satisfied with your decisions.
It concerns which outdoor lights should be controlled manually or automatically.
The property is a detached house. The street view shows the entrance with a canopy in the middle of the left side of the house, a small front garden with a path on the left and right, a carport with an additional parking space in front on the right side of the house, and a larger terrace with stairs leading to the garden at the back.
I have planned one light under the entrance canopy, controlled manually from inside.
In the front left corner, a motion sensor light, not manually switchable.
In the front right corner (in front of the carport), another motion sensor light, also not manually switchable.
Here is the question whether fully automatic control makes sense, or if it might be better to have an option for manual switching as well.
Under the carport, I plan a separate manually controlled light (because the motion sensor probably won’t work there) in case you need to load or unload the car in the dark.
The question here is whether it would be better to link this to a motion sensor with a long delay timer?
On the terrace at the back, there are three lights on the house wall, currently only manually controlled. I’d like to convert them to include motion sensors to deter burglars. What do you think, would that be sensible?
I’m also considering adding an automatic dusk sensor. Does that make sense? I often travel for work, so it might make the house appear more occupied.
There are also two small step lights on the stairs to the garden, manually switchable only.
Additionally, wiring for perimeter spotlights in the fascia board is planned, though I’m now questioning whether I will actually install them. Probably not.
It has also been agreed to lay underground cables in the front garden and behind the house, in case there is a future need to light pathways.
Would the front cable then be connected to both motion sensors depending on which direction you want to illuminate in front of the house? Is that even possible? How did you implement this?
Regards
JaiBee07
21 Oct 2022 18:43
Patricck schrieb:
After that, it switches to motion sensors, and when we go to bed, the lights turn off until 6 a.m., then the motion sensors take over until it gets light. We don’t need any lights while we’re in bed, not even outside.
Do you really not see the motion sensor as a deterrent? I’m just surprised you turn it off completely at night.
