ᐅ Optimization of the Installation Location for Air-to-Water Heat Pumps
Created on: 12 Dec 2019 12:10
CrazyChris
Hello everyone, I am currently considering the installation location for our air-to-water heat pump as a split system.
According to the current plan, the outdoor unit is positioned in front of the house facing west toward the street. Unfortunately, this means the unit is constantly exposed to wind and weather. Our local climate is cold and very windy. On the plus side, no neighbors seem to be disturbed.
An alternative option would be to place the outdoor unit on the east side, in the corner between the house and the garage. This location would offer better protection from the weather and a significantly shorter distance to the indoor unit. The issue is that it would be approximately 3.5 meters (11.5 feet) away from the currently undeveloped neighboring property, whose owner might potentially build up to 3 meters (10 feet) close to our property line. This would leave the outdoor unit just over 6 meters (20 feet) from their building, raising concerns about noise sensitivity. Due to the corner position, I also suspect there might be stronger noise emissions.
The garage roof is not an option.
Attached is a rough sketch.
I would appreciate any opinions or suggestions.
Site plan: house bottom left, garage top right; two red alternative positions marked.
KingSong12 Dec 2019 13:49
You will not notice any difference in efficiency with an air-to-water heat pump, regardless of whether it is installed on the windward side or not. In your alternative 2, the corner solution, I would have more concerns regarding thermal short-circuiting. It is actually beneficial if the wind can quickly carry away the generated cold air.
CrazyChris
12 Dec 2019 14:38
Great, thanks for the information
halmi
12 Dec 2019 14:40
We have almost the same conditions as you, and our unit is located by the street.
It might not look as "nice" placed in front of the house, but we prefer that over having it in the backyard.
