ᐅ The outlines of the insulation are visible on the exterior wall.
Created on: 2 Jan 2017 20:42
kaladze
I’m new here and have read quite a bit offline so far. Now I have a problem myself—or maybe not. I’m a layperson and will try to explain everything as clearly as possible.
We bought a condominium last year. The building was constructed in 2015 and has external insulation. Now, with the freezing temperatures, you can see the insulation panels on the north and east sides of the building where there’s no sunlight. The blocks are clearly visible. There is also frost on the facade, like a light layer of snow. The facade on both sides is also dirty, with slight black spots. Probably caused by a thermal bridge where heat escapes between the panels.
On the south and west sides, this isn’t visible. The developer says this is normal, that every insulated building experiences this, and the black spots will eventually disappear. Somehow, I don’t believe him.
We, the owners, are seriously concerned that damage may occur. Before we send an official letter, we wanted to ask for good advice here. Did they cut corners? Or is this really normal?
Thank you very much in advance and Happy New Year 🙂
Weißes Haus von außen mit kleinem Fenster unter der Dachkante.
Außenansicht eines Hauses mit Fenster in heller Wand und schrägem Dach
Außenwand eines Hauses mit kleinem rechteckigem Fenster und Regenrinne links.
Rote Fassade mit zwei quadratischen weißen Fenstern, blauer Himmel im Glas
Außenansicht einer hellblauen Fassadenwand mit Fenster
Außenansicht einer Betonfassade mit zwei quadratischen Fenstern
kaladze
3 Jan 2017 12:32
As I understand it, it could be anything. We hope that it’s nothing serious and that everything proceeds without legal disputes. I will keep you updated.
Farilo
11 Jul 2017 17:38
Hello Kaladze,
May I ask how things are progressing?
Hopefully, everything has turned out well.
