ᐅ Renovating an Older Home: Underfloor Heating or Radiators?
Created on: 2 Jan 2019 17:55
J-F-E
J-F-E
2 Jan 2019 17:55
we recently bought a mid-terrace house in need of renovation (built in 1970). We are still at the very beginning of planning the renovation and remodeling, but we are already trying to gather some ideas.
One of the many decisions to be made is the heating system.
Whether to go with a gas condensing boiler, an air source heat pump, or a combination of both remains to be seen. One thing is certain: I would like to have a photovoltaic system on the roof and a fireplace in the living room.
Regarding the type of heating, we face another question that needs to be decided in advance. Should we install new radiators, or would it make sense to switch to underfloor heating since all floor coverings and old radiators will need to be removed anyway? Does anyone have experience with either option or good advice?
Many thanks!!!
Knöpfchen2 Jan 2019 18:02
Understood. Obtain cost estimates.
J-F-E
2 Jan 2019 18:10
Knöpfchen schrieb:
Sure.
Get cost estimates.
Under "Tips," I was expecting something different...
Knöpfchen3 Jan 2019 10:03
I admit, that wasn’t very original. It wasn’t meant to be offensive either. But with such a vague general description, there isn’t much to offer in terms of advice.
wrobel5 Jan 2019 14:20
Hello
To install underfloor heating, it is not enough to just remove the floor coverings; the screed must be removed and the entire construction including insulation needs to be redone. This is a completely different level of cost compared to replacing radiators.
Olli
caddar
5 Jan 2019 16:10
We are currently in the middle of renovating an older building (a house from the 1960s) and had the same question. In the end, we chose the "classic" radiators (or a modern design of them).
One reason was the ceiling height. With our "old" floor structure, the room height is about 2.55 meters (8 feet 4 inches), but with underfloor heating, it would be closer to 2.47 meters (8 feet 1 inch). Besides the costs (which are already significantly higher than just replacing the flooring), this was the deciding factor.
