ᐅ My KALLAX unit tips over when the vacuum cleaner bumps into it – any ideas?
Created on: 27 Nov 2023 08:47
pijome
I have an issue with my KALLAX shelf that is honestly quite annoying. Whenever I vacuum next to it and the hose or nozzle bumps against it, the entire unit tilts slightly forward. The shelf isn’t fully loaded, but it seems to be positioned quite close to the wall and standing on laminate flooring, which is not slip-resistant. By now, this worries me because I’m afraid something might eventually fall or get damaged.
Does anyone have any ideas on how to make the KALLAX more stable? I’m thinking about anchoring it to the wall, adding extra feet, or maybe using an anti-slip element. I’m not looking for a completely different solution, just practical tips that are easy to implement. Thanks in advance!
Trate47
29 Nov 2023 07:52
pijome schrieb:
Does anyone have an idea on how to make the KALLAX more stable?
Hey, maybe a DIY approach could help: sometimes it’s enough to attach a wooden strip along the front bottom edge, which prevents tipping by friction. It’s quick to do, and if the vacuum cleaner bumps into it, you have a small barrier that keeps the shelf steady.
Of course, only if the look and space allow it. And yes, wall mounting is even better, but this might be a quick and easy interim solution 😉
Alternatively, rubber or silicone stoppers are another option – they grip really well and can be easily screwed or glued on.
