ᐅ Adjustable TV Mount for Ikea Besta Unit
Created on: 25 May 2012 13:22
ddn2702
ddn2702
25 May 2012 13:22
I’m currently facing the following issue:
For the Besta cabinet with the Främsta back panel, there is only one original TV mount available, which hooks onto the rails. Unfortunately, this mount neither swivels nor tilts.
However, I definitely need a TV mount that can both swivel and tilt. Has anyone else had the same problem and successfully found a solution?
I have already considered buying the Främsta mount and using only its mounting brackets for the rails, in order to attach a third-party mount to them. The question is whether the two upper mounting brackets alone would be sufficient or if I also definitely need the two lower ones.
Daniel
IKEA-Experte
29 May 2012 15:28
You will definitely need the lower ones as well. The question is whether the external bracket has sufficiently large hole spacings to make this possible. I have also considered this problem and thought about mounting the external bracket onto the vertical supports of the Framsta bracket. The only thing I'm not sure about is whether the Framsta rails can handle it, since the forces on the rail increase with the distance of the TV from the wall (lever effect).
