Our house has a separate apartment. The previous tenant, from when the house was not yet ours, left it in a condition that was certainly not ideal.
We recently removed the baseboards and encountered a surprise. We naively assumed they were painted white, but it turned out that, for some unknown reason, they had been sealed with silicone. This is very unusual, especially since the apartment was unoccupied for almost a year and apparently not ventilated or heated as we had expected. In any case, there is mold under the baseboards.
We measured the moisture level with a moisture meter and it was around 80. At least on the surface, the wallpaper shows no visible signs.
We plan to leave it open like this for about four weeks with proper heating and ventilation. After that, we intend to treat the area with a mold remover. Do you have any recommendations for this? Would you approach it differently or have other tips? Thanks!
Bieber081522 Jan 2018 10:02Mizit schrieb:
Can you recommend anything here, would you do it differently, any other tips? The most important thing, of course, is to identify the cause. Why is/was the moisture level so high there? Was there a single event, such as flooding? Or is there a leak that continuously wets the floor/walls?
Then:
- Eliminate the cause
- Dry the area (heating, ventilation, if necessary use mechanical drying)
- Renovate
