cybergnom23 Nov 2021 12:23Hello everyone,
I have a Zehnder mechanical ventilation system with heat recovery. What is the minimum distance required between the air supply outlet and any obstacles?
Background: I want to place a wardrobe in the bedroom, which would unfortunately stand directly in front of the air supply outlet. The distance would be about 3-4 cm (1-2 inches).
Is that okay, or would this impair the system’s function?
Thanks and regards,
cybergnom
Thanks and regards,
cybergnom
That’s hard to say, but I tend to lean towards "yes." It can be helpful if the base of the cabinet has ventilation openings at the front.
cybergnom23 Nov 2021 16:49Mycraft schrieb:
Depending on the valve used, noise may occur. If you use a flat one that vents to the side, there are no concerns regarding functionality. It is a Zehnder CLD-P.
Noise generation is not a big issue as long as the function is ensured.
