ᐅ LWZ 304 location in a semi-detached house, garage without corners, how to install
Created on: 4 Dec 2013 08:33
sparfuchs2012
sparfuchs2012
4 Dec 2013 08:33
After a lot of consideration, we have decided to plan for an air-source heat pump for our semi-detached house. Since we don’t have a large plot of land, we would like to install the air-source heat pump in the basement. We have chosen a Stiebel Eltron LWZ 304.
Because of the garage layout, we don’t have any corners where we could route the supply and exhaust air ducts around the corner. Has anyone experienced the same issue? If so, how did you solve it for your semi-detached house?
Marcus
€uro
4 Dec 2013 14:43
sparfuchs2012 schrieb:
...after much consideration, we have decided to plan an air source heat pump for our semi-detached house.
It is rather unusual that you apparently are qualified building services engineers and energy consultants, as this is not obvious from your inquiry. How does that come about?
The term "planning" actually implies engineering services and results, regardless of whether it concerns construction or building services engineering!
Sometimes it helps to differentiate between the terms "planning" and "provision, intention..."
