ᐅ Location of the multi-service building entry (MSH)
Created on: 31 Jul 2019 21:09
baum2020
I am currently planning the multi-utility house entry in our utility room. I would like to install it in a space-saving and unobtrusive way. The furniture and doors are not finalized yet. However, the room will not be adjacent to any exterior wall. There will be a separate side door leading to the garage. Behind this door, I would like to place the multi-utility house entry. At the same time, I would hang the electrical panel above it.
Does anyone have a similar setup? Is this easily feasible? How much space should be left approximately?
We are building without a basement. Connections for electricity, water, telecom, and reserve.
Küche von oben: Eine Person steht am Arbeitsbereich; links ein großer weißer Kühlschrank (Gelbkreis).
Grundriss eines Gebäudeteils mit den Räumen 2, 4 und 6; Möbel, Türen, Treppen, gelbe Markierung.
baum2020
3 Aug 2019 18:14
I suspect this won’t work because the refrigerant lines are rigid pipes, not flexible hoses. Does anyone know how the routing of these pipes through the building structure typically looks in a case like mine? I assume that for structural reasons, the pipe assembly won’t be installed in the exterior wall but rather routed through an installation shaft?
