ᐅ Lawn mower or scythe?
Created on: 19 Nov 2008 13:04
Nagel-1
19 Nov 2008 13:04
We have a large meadow behind the house that we want to leave entirely natural. We want everything to grow as nature allows. However, it should be mowed once a year. Is it better to use a lawn mower or a scythe for this? Who has experience with this and can tell me which is easier to use?
Hansi-1
19 Nov 2008 13:45
If the meadow is only going to be mowed once a year, then using a lawn mower is not an option. The grass will be too tall, and you will never get through it. A scythe is a better choice, but you need to practice. There is a specific technique required, otherwise it won’t work.
Helmi-1
20 Nov 2008 07:40
There are also mowers that can handle tall grass, but they are quite expensive. It is much better to learn to mow with a scythe. Maybe you know someone who can show you how to do it. It’s also a great fitness exercise, and once you’ve mastered it, it becomes very quick.
Tomcat-1
20 Nov 2008 21:26
We have a similar situation behind our house, and I have to say: we use both. The tall grass and brush near the fence are cut with a scythe, sometimes with our gas-powered trimmer, and then the rest is finished off with the lawn mower – so it’s definitely useful to have both at home. 😉
Förster-1
26 Nov 2008 08:11
Meadow
Hello
If you want to have a truly natural meadow, mowing it just once a year is questionable. Many plants cannot withstand this treatment and will eventually die out over the years.
It is also advisable to cut the meadow only with a scythe or a sickle bar mower. The scythe cut does not go as deep or as cleanly as a lawn mower. The grass stems generally remain longer, which better preserves the natural meadow. The sickle bar mower is recommended for larger meadows since using a scythe is only easy if you have mastered it, whereas with a sickle bar mower, it’s hard to go wrong.
In any case, the most cost-effective option is the scythe. It is relatively inexpensive and only powered by muscle strength 😉 For a natural meadow, it also makes the most sense to mow with a scythe =).
Best regards, Förster
