ᐅ Is there a trick to making Ikea BESTA drawers quieter?
Created on: 21 Feb 2023 18:07
Sayed47
Hello everyone, I have a question that’s really bothering me about my IKEA BESTÅ drawers: Is there a way to make these specific BESTÅ drawers quieter? Specifically, I’m referring to the slight but often disruptive clicking and snapping sound that occurs when these drawers close – even when you close them gently. I’ve already tried lubricating the drawer slides, but the result was only mediocre and only partially reduced the issue. It would be great if someone here in the forum has experience or practical tips on how to significantly reduce the noise when closing BESTÅ drawers without compromising their functionality or stability. Thanks in advance!
Ramon4
23 Feb 2023 10:05
Good question, @Sayed47. Basically, a clean and lubricated guide rail ensures smooth operation and reduces mechanical wear.
- Silicone oil usually results in less friction and should be preferred for plastic guides, as it does not cause sticking.
- Felt or foam rubber strips mainly reduce impact noise and have little effect on the mechanics themselves, as long as they are applied correctly.
- Occasionally tightening the screws prevents loose fittings, which could lead to increased wear.
Overall, these measures are more gentle than stressful, as long as they are carried out carefully.
