Dear forum members,
According to the scope of work from my construction supervisor, the connection capacity for the house will be 14.5 kW.
Is that sufficient for a modern single-family home with 5 people?
I understand that most appliances are not necessarily running at the same time, but if I imagine that in winter many devices might be used simultaneously, and then a 2 kW hairdryer is added, the limit could be reached.
What would actually happen in that case?
Is it possible to upgrade the connection capacity, or are there restrictions imposed by the utility company?
How does a photovoltaic system affect this? Can it increase the maximum peak power demand of a house, or is it useless if the electrical installation itself is not designed for higher loads?
Thank you and best regards
Tolentino
Tolentino
In general, consumers must register with the utility provider starting from 6.9 kW.
This naturally also includes a charging station.
Charging stations with 22 kW usually require approval,
so you will need authorization or permission from the utility provider for these.
As mentioned before, the complete wiring, including meter wiring for 50 A or higher, is not sufficient with the usual 10 mm² (8 AWG) cables.
NatureSys26 Jun 2020 20:18Is it necessary to register the sauna heater with the utility provider?
Generally, this applies at higher power levels.
Exact details about the required power level can be found in the tab provided by your utility company, which is publicly accessible on the internet.
Your electrical contractor, who also connected the system, will handle the registration. They should definitely initiate this process.
It is basically just a formality to inform the utility company about the potential loads on their supply network.
There is no additional cost for this.
