ᐅ Is it practical to have a wildflower meadow facing northeast? Any experiences?
Created on: 11 Mar 2024 07:29
world-e
world-e
11 Mar 2024 07:29
We have a plot of just under 450m² (approx. 4,840 sq ft), which is relatively small. Most of the outdoor area is already completed, but there are still some ongoing projects. For one garden area of about 25m² (270 sq ft), the plan so far was to sow a wildflower meadow. However, this area faces northeast, so it receives very little sunlight. From my research, there are flower seeds available that are suitable for shady locations.
Do any of you have experience with flower meadows in shaded areas or in general? Or do you have other suggestions?
Here is the plot. The light blue area is the one in question. Neighbors are located close by at the bottom left and right. Above, following the curve, there is a road.
Floor plan of a house with garage, two terraces, driveway, pool area, and garden.
Thank you very much
SoL
11 Mar 2024 07:33
No problem, it works. We have the same here. The flowers are just different than on a south-facing side, but a wildflower meadow works in any direction.
Evolution clearly took that into account...
world-e
11 Mar 2024 07:54
SoL schrieb:
No problem, it works. We have it here too. The flowers are just different compared to a south-facing orientation, but a wildflower meadow can thrive in any direction.
What has your experience been regarding maintenance, etc.? Would you do it again? Do you still remember the seed mix?
Thank you very much
WilderSueden
11 Mar 2024 08:07
I wouldn’t worry too much about that either. Use a high-quality mix of native wildflowers from your region, for example from Syringa or Rieger-Hoffmann. The cheap mixes from hardware stores mostly contain annuals. This results in a burst of flowers in the first year, but by the second year you’ll mostly see grass and weeds.
A wildflower meadow is mowed twice a year, in June and September (if the soil is very nutrient-rich, possibly three times). In June, it’s recommended to leave the cuttings on the ground for 2 dry days before removing them, so the seeds can drop. With good mixes, it takes about 2 years to look really nice, because the perennial plants only form rosettes in the first year and start flowering from the second year onward.
SoL
11 Mar 2024 08:13
We have practically no maintenance required, see @WilderSueden.
The wildflower meadows in our garden developed naturally; the only one we planted ourselves worked only on the second attempt, using high-quality seeds (see post above).
