ᐅ Insulation of window reveal, exterior wall insulation system (EIFS), and brickwork including the transition areas
Created on: 18 Jun 2016 13:01
SimonMoers
I have the following wall construction:
Ground floor: brick 175mm (7 inches), mineral wool 120mm (5 inches), air gap 15mm (0.6 inches), facing brick 105mm (4 inches).
Upper floor: brick 175mm (7 inches), external insulation system (EIFS / external thermal insulation composite system) 135mm (5.3 inches).
What is the best way to insulate the window reveals? Can I use XPS (extruded polystyrene) reveal boards with the EIFS on the upper floor, even though the EIFS insulation is made of mineral wool? Or should the same insulation material be used throughout?
How do you best create a transition between the EIFS and the facing brick insulation? We want to use mineral wool boards behind the facing bricks, and also mineral wool in the EIFS, but the EIFS boards will be a different type than the simple attachable boards behind the facing bricks. Do you have any reference websites or resources for me?
Bauexperte
18 Jun 2016 22:38
The difference between glass wool and stone wool is not very significant; a layperson only notices it by the color.
Bauexperte
Sebastian79
19 Jun 2016 07:06
Very nice – we only had basic fiberglass insulation, but on the roof I used stone wool.
Legurit
19 Jun 2016 12:27
Isn't that basically the same?
Bauexperte
19 Jun 2016 12:34
As mentioned* ... roughly. Stone wool offers better sound insulation but is also more difficult to install because the boards are "stiffer"; that's basically the main difference.
Edit: *for Sebastian
Regards, Bauexperte
Sebastian79
19 Jun 2016 13:11
Your English is terrible
Bauexperte
19 Jun 2016 15:02
With this observation, your ego has found a little treat after all
Bauexperte
