ᐅ Ikea Metod Kitchen – Assembly Challenges
Created on: 10 May 2015 16:50
IKEA-Experte
in the next steps, the ventilation is suddenly attached directly to the back panel
No, on page 11 it shows that the grille should be discarded.
IKEA.com/de/de/assembly_instructions/bejublad-backofen__AA-718049-3.pdf
When I place the divider panel on the two rails, the 6 screws don’t reach the holes in the rails. They are just a little too short
The screws are 25 mm (1 inch) long in total, and the base is 18 mm (0.7 inch) thick. So the length of the screws is not the issue.
The thread on the rail is slightly bent downwards
I don’t understand that.
I would remove the rails again and try screwing them onto the base first. That might help identify the problem more clearly.
Should the oven edge align flush with the metal rail (where the stoppers are attached) at the top? If so, I would have to push the rails higher up inside the cabinet
At least almost flush. Do the bottom edges of the rails have a distance of 169 mm (6.7 inches) from the base as specified?
How do you get this to the same height as the other cabinets?
Screw the feet up as shown on page 14.
ikea.com/de/de/assembly_instructions/medelstor-geschirrspuler-integr-__AA-1402820-1.pdf
How do you attach this front panel to the dishwasher? Unfortunately, there were no instructions for this either.
Actually, this is shown starting on page 11.
IKEA-Experte
12 May 2015 16:58
1. The rear foot is fully screwed in. On page 10, step 8, you can see in the enlarged detail views and in the top info box that there is a screw at the front which adjusts the height of the foot. If this does not work, the shaft may have slipped out or the rear foot is screwed in too tightly and needs to be loosened directly. For this, the appliance must be tilted.
2. The sealing strips seal the gaps between the dishwasher and the cabinet carcasses on both sides.
