ᐅ How can I securely attach IKEA Besta units to the wall?
Created on: 15 May 2021 09:17
TEUN44
I am planning to securely fix an IKEA Besta shelving unit to my wall. Since these shelves are often quite tall and can be heavily loaded, I want to make sure there is absolutely no risk of tipping over. My wall is a typical load-bearing interior wall made of concrete, and I intend to use anchors and screws that can support the weight.
However, I have the following questions that concern me especially:
- What fastening materials are recommended for Besta units on concrete walls?
- Do all Besta components always need to be fixed to the wall, or is securing just the top part sufficient?
- Are there any specific tips during installation that make the shelving more stable, such as using special brackets or additional connectors?
- What is the best approach to aligning and measuring to ensure everything is level and straight?
I would appreciate any experience or concrete advice on mounting IKEA Besta units on concrete walls. Thanks in advance!
keogla
17 May 2021 14:18
Always make sure to use the correct anchors for concrete applications and insert them deep enough into the masonry. Secure shelf brackets with at least two screws to ensure stability against torque. Avoid placing weight directly at the front of the shelf; it is better to position heavy items at the bottom.
