I am planning to securely fix an IKEA Besta shelving unit to my wall. Since these shelves are often quite tall and can be heavily loaded, I want to make sure there is absolutely no risk of tipping over. My wall is a typical load-bearing interior wall made of concrete, and I intend to use anchors and screws that can support the weight.
However, I have the following questions that concern me especially:
- What fastening materials are recommended for Besta units on concrete walls?
- Do all Besta components always need to be fixed to the wall, or is securing just the top part sufficient?
- Are there any specific tips during installation that make the shelving more stable, such as using special brackets or additional connectors?
- What is the best approach to aligning and measuring to ensure everything is level and straight?
I would appreciate any experience or concrete advice on mounting IKEA Besta units on concrete walls. Thanks in advance!
For securely mounting IKEA Besta units on a concrete wall, I recommend the following approach:
- Use heavy-duty anchors (e.g., expansion bolts or chemical anchors) that are rated for the expected load.
- Use the supplied wall brackets attached at the top of the Besta unit. These prevent tipping.
- For particularly tall or long shelves, additional brackets on the sides or at the bottom can increase stability.
- Before drilling, carefully measure with a spirit level and tape measure to ensure the shelf is level.
- Check the load-bearing capacity of the wall and, if necessary, the placement of electrical wiring or plumbing.
If the shelf will be heavily loaded, a double securing method is advisable. Fastening only at the top is technically sufficient but may wobble under heavy load.
Hello and thank you for your well-formulated question!
I have personally mounted several IKEA Besta shelving units on concrete walls, so here are a few tips based on my experience:
- First, you should pre-drill the wall with a suitable drill bit for concrete (e.g., a masonry drill bit, diameter matching the wall plug).
- Heavy-duty wall plugs are best, as they securely hold the shelf even when fully loaded.
- Use the included brackets wisely positioned; make sure to screw them firmly into the wall.
- Mounting only at the top is usually sufficient for normal loads, but if you have children or there is a risk people might lean on it, it doesn’t hurt to use brackets at the bottom as well.
- When measuring, be sure to use a precise spirit level, otherwise, the entire shelf may hang crookedly, which affects both stability and appearance.
Overall, safety in fixing is very important, especially when heavy items or lots of weight will be placed on the shelf. I don’t want to scare you – with the right materials, this is easily achievable.
SUBEN60 schrieb:I can confirm this; chemical anchors are especially strong if you don’t mind the extra effort.
Use heavy-duty wall plugs (e.g., anchor bolts or chemical anchors) designed for the load.
To add to the previous statements: The choice of fasteners is crucial. For concrete walls, expansion anchors are often the best choice due to their high load capacity. If the wall has cavities or irregular areas, chemical anchors (injection mortar) may be more suitable, as they distribute the load effectively even in porous materials.
I also recommend holding the shelf against the wall temporarily before final fastening and carefully marking all drilling points. This helps avoid errors in positioning.
If you are interested in extra security, additional brackets on the sides are useful, especially if the furniture piece is prone to tipping.
Julien schrieb:This is a key point because stress in the material caused by inaccurate installation can weaken the connection.
When measuring, be sure to use a perfectly level tool; otherwise, the entire shelf may hang unevenly, which affects both stability and appearance.
anken schrieb:
If you are interested in double reinforcement, adding extra brackets on the sides makes sense, especially if the piece of furniture is prone to tipping. I can confirm that. More brackets increase stability. However, with solid concrete walls and normal loads, the brackets at the top are usually sufficient.
