Hello everyone, I recently purchased an Ikea Metod kitchen and am generally very satisfied, but unfortunately, I noticed some minor damage on several cabinet fronts—mainly scratches, chipped corners, and a few spots where the surface is slightly damaged.
I’m interested in how I can best repair these damaged fronts myself without having to replace them entirely. Are there proven methods, materials, or special repair kits you would recommend?
Tips on preparation, handling the surfaces, and possibly suitable painting or filler techniques would also be very helpful. It’s important to me that the result looks as inconspicuous as possible and doesn’t further damage the surface.
Thanks in advance for your expertise!
gordonjo schrieb:
How much should you sand without further damaging the film coating?The goal when sanding is not to remove the film completely but just to smooth out the rough spot slightly. A 320-grit sandpaper or a fine sanding sponge is ideal. Apply light pressure and give the surface time to breathe. Avoid using a machine right away unless you have experience. Hand sanding is better than rushing.
olivernu schrieb:
The film surface is very thin, so it’s better to sand lightly and often rather than too aggressively once.Exactly, that’s one of the most important rules, otherwise the damage will be more noticeable afterward than before.
If you’re unsure, try it on an inconspicuous corner first.
