ᐅ How can I professionally and evenly paint Ikea BESTA fronts?
Created on: 21 Jun 2023 08:27
Sauru
I’m planning to repaint my Ikea Besta fronts and want to achieve a truly professional and even finish. So far, I have only painted furniture in a basic way, but never specifically Besta fronts, which are often made of coated or melamine resin-coated material.
My specific question is:
How do I best prepare the surfaces, which type of paint is most suitable for durable, resistant fronts, and how can I ensure the paint finish is really even—without runs, bubbles, or uneven joints?
Are there any particular techniques or tools that are especially recommended for these types of fronts?
I have considered spray paints but have no experience with them.
Thanks in advance for your tips and experiences!
Sauru
23 Jun 2023 19:14
meGreg schrieb:
What also helps a lot are painting stands that allow you to paint cabinet fronts on both sides without having to set them down – this prevents damage to the wet paint.
That’s a great tip! I’ve been wondering how to store the often quite bulky cabinet fronts without damaging the fresh paint. Do you have any advice on how to build such stands yourself? Or would a simple garment rack with hooks possibly be enough?
nedagla schrieb:
Take the time between coats to lightly sand the paint (for example, with 400 grit wet sandpaper)
Do you really have to wet sand? I’m unsure if I’m doing wet sanding correctly. Is dry sanding sufficient, or is wet sanding significantly better?
I’d appreciate hearing about your experiences!
